Fan wiring?
Old Aug 18, 2002 | 11:15 PM
Trent257's Avatar
Fan wiring?
right now i have my fan wired up to a switch, but i want to wire it so it turns on with my car and turns off with it, how can i do that?
Old Aug 19, 2002 | 09:12 AM
MdFormula350's Avatar
well i have the factory dual fan electric setup, and all i did is wire a switch into the tan wire that goes to the relay..
this tan wire is the wire for the factory fan switch which goes into the passengers side block and controls the passengers fan.
all that wire does it ground the relay, and only works when the ingintion is on.. so just hook one of the new switch wires to the tan wire some where before the relay connection.. and the other wire of the new switch to the a good ground on the body..
so you can turn the fan off and on when the car is on!!
good luck i hope this helps.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
