need some quick help with wiring a fan switch
Old Jul 17, 2001 | 11:15 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i was told so i could turn it on and also it would be able to work without flipping the switch is to connect a wire from the ground switch on the passenger head to a toggle, and the other end of the toggle to a ground... now on the back of the head is a weird looking sensor thing..then 2 wires,ones black with a white stripe and the other is white..what am i splicing into??!
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 24, 2001 | 05:44 PM
evilho7810's Avatar
The sensor is under the 3rd spark plug on the passenger side not the back of the head. I think it only has one wire not two.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Dkelz313
Apr 7, 2016 10:38 PM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
