How to hook up a power seat
Old Aug 19, 2002 | 06:15 PM
Makai's Avatar
I put the seat in, now where do i plug in the 2 prong connector
Can I ground it to the seat itself? I hear it goes to any power source, but i need a little guidence.
Please advise,
Thanx, Marie
86 TA 305 4 barrel carb
Old Sep 2, 2002 | 12:00 AM
ikilu2's Avatar
I installed power lumbar seats into my Bird which came out of a GTA. I grounded the black wire directly to the sheetmetal (where I am sure I can get a great ground connection). The orange wire I connected to the electrical acc. box to the left of the fusebox above the kick panel and added an extra fuse (for safety). This is where it plugged into from my donor car and is a secure and safe connection which will last the life of the car. I wouldnt just tap into any circuit because look at the gauge of the orange wire, it's thicker than the normal 18 or so gauge thats normally inside the interior. That means it uses a greater amprege. What would happen is if you tap it into a lower amp circuit and use your seat you might always blow a fuse because a circuit is designed with a certain amp in mind. Hope this helps!
Old Sep 21, 2002 | 12:59 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I just used a T-bar connector to clamp into the cigarette lighter. I don't smoke, and I still have an accessories plug if I ever need it. No fear of blowing a plug because once I set my seat I haven't moved it since, but I have tested the lighter and the seat at the same time. No problems whatsoever.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Accerrito22
Aug 23, 2015 07:22 PM
