V6 Tach in V8 Car
Old Jul 26, 2001 | 01:04 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
V6 Tach in V8 Car
I have a 91 RS V8 that I drive and a 91 RS V6 wrecked parts car. I would like to use the tach from the V6 Car which shows a 6k rpm redline instead of my 5k redline on my car. Is the tach a separate component of the guage cluster. Is it programmed for V6 signal or does the computer actually control the tach reading. I hate to try and remove the face plate. I don't think I can get the needle off and back on without screwing up something.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 26, 2001 | 05:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
They are different and will not work. You cannot just change the faceplate either, since the needle will read where the old faceplate used to.
There is a little computer board that performs all the algorithims for the tach. If you could find some way to put the V8 board on the V6 tach, it might work, but can't make no garuntees.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Dec 5, 2003 | 05:36 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I thought the tach filter controlled the signal to the tach? They both have the same needle movment, scale, and electonics boards, are you sure this won't work? The tachs aren't computer controlled, but they do send a signal to the computer for the shift light actuation, from what I have read.
Old Dec 5, 2003 | 10:47 PM
3rdGenBlackBird's Avatar
A v8 was swapped into my car, and I still use the v6 tach. It's not accurate but it will work... although that probably doesn't help you any. I like the way the v6 tach looks better than the v8 tachs that I've seen. Oh well.
Old Dec 6, 2003 | 09:58 AM
Morley's Avatar
Do a search. There is a component that you change on the V6 circuit board that will allow it to work correctly with a V8.
$750 L98
Feb 1, 2025 02:25 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
