Putting a gauge cluster from an 84 std ,or IROCs into my 85 sport coupe, need help
Old Jul 28, 2001 | 10:19 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I got the gauge cluster from a 84 or earlier standard camaro,it has analog and my SC has idiot lights that caused all my problems.I also have a cluster form a 87 IROC, and when I went to put 84 standards into my SC the two connectors in the back wouldnt fit.I dont have my dash in and could this be the problem.When I force the connectors in they still pop out.
Are there different styles of connectors?
Will all of the gauges work when I get it in right,cause ive heard that the oil pres will peg out.
Old Jul 28, 2001 | 11:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
82-89(?,,might be 90,, I'd have to look at the breakdowns again) should be the same,, the whole cluster will pulg right in. If you go from 'idiot' lights to gauges,, you have to replace the sensor accordingly,, the speedo & tach will work properly though (v6 tach will not read properly on a v8 though)
The mind is like a parachute, it only works when its open
Old Jul 29, 2001 | 10:12 AM
Car: 85 Camaro SC
Engine: V6
Does it matter when you dont have dash in,cause when I put the connectors in they just come right out when the gauge cluster moves.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
mustangman65_79
Aug 11, 2015 03:17 PM
