VATS and steering column
Old Aug 22, 2002 | 07:06 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey all I may have to replace my steering column. The one I have in the car now has VATS and the other may not. Will this make a problem for me? I do not know much on the subject so I am coming to you all for help. I know it works from the key Correct? so how would a column that came before VATS work or will it?
Thanks for the help
Brian Felts
Old Aug 24, 2002 | 09:04 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
THE DIFFERANCE IS THE IGNITION SWITCH HAS A WIRE TO READ THE KEY. YOU CAN TRANFER IT OR PUT A RESISTOR IN THE CONNECTOR .
Old Sep 9, 2002 | 04:01 PM
johnnyformula's Avatar
if they don't save the ignition cylinder, measure the resistance in the chip in the key, then wire in some resistors at the same value to the two white wires in the orange sheath under the dash.
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Night rider327
Sep 25, 2015 04:19 AM
