Any 3rd Gens (Camaro) have Electronic Speedo?
Old Jul 29, 2001 | 03:05 PM
multi-tasking's Avatar
I am working on a V6 to V8 Swap. My V6 speedo is mechanical. Is there an electronic speedo that I can install in my car that bolts up/wires in to the V8 without a lot of pain?
The Engine/tranny combo that came out is 2.8L/4L60(V6 version). Going in is 5.7L/4L60(V8 version) speed density.
If I posted this in the wrong I am sorry...
m-t
m-t
Old Jul 29, 2001 | 06:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
90+ Camaros and 86+ Firebirds are electronic speedometers.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jul 30, 2001 | 05:46 PM
Thanks Kevin91Z
m-t
Old Jul 31, 2001 | 01:25 AM
bigblue's Avatar
<font face="Verdana, Arial" size="2">90+ Camaros and 86+ Firebirds are electronic speedometers</font>
Is the '86-'89 bird speedo interchangable with '90-'92 bird and camaro speedos?
Old Jul 31, 2001 | 07:27 PM
Yea, I am having a hard time finding information concerning which (if any) of the later models Camaro (90-92) speedos will work.
And, what is the purpose of the cruise control transducer and how does it relate to the speedo?
m-t
Old Jul 31, 2001 | 11:54 PM
Kevin91Z's Avatar
From what I know, the Firebird dash is the same from 85-92, so you can put an electronic speedo in a mechanical dash.
However, the Camaro's changed dashes in 1990, and the half-moon speedos in 90-92 wont fit in the circular speedo holes of the 82-89 Camaros.
However, the easy solution for you is to get a mechanical speedo from an earlier 700R4 transmission. It'll plug right into your 4L60 trans and work just fine with your stock cable-driven speedo. Then you'll need a special adapter that plugs into the trans and provides the 4000 pulse speedo signal for the 90-92 TPI computer. I think you can get it from TCI or B&M.
Old Aug 1, 2001 | 06:20 PM
Thanks... And on to the next problem...
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
I'llrocya
Feb 2, 2016 11:43 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
