87 Trans Am VSS problems
Old Jul 31, 2001 | 09:55 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I have a 87 Trans Am GTA with a digital Dash. It had a engine fire. The porblem is that i need to know where the wires from the sensor go through the fire wall? How they get inside the passenger compartment. via with the rest of the computer wiring or the C100 connector on the driver side. ECT... Any help would be greatly appreciated!!!
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire hope to get running soon
Flowmaster exhaust
Old Jul 31, 2001 | 10:55 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
All of the computer controlled sensors come from the pass side via the door mount pillar. The gauge senor & majority of power wiring comes from the plug on the firewall just right (looking at from the front of the car) of the brak booster & the headlight wiring comes from a grommet just under the brake booster.
*edit- the a/c wiring comes (mostly) from a grommet just behind the pass side exhaust manifold
The mind is like a parachute, it only works when it's open
[This message has been edited by deadbird (edited July 31, 2001).]
Old Aug 2, 2001 | 09:02 PM
AaronIROCZ's Avatar
Yeah I already know that but my service manual does not show where it goes to get inside the pass. compartment. Is it included with the computer wiring or what? Otherwise i will drill a hole under the counsole and run it through there.
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
Flowmaster exhaust
Old Aug 2, 2001 | 10:28 PM
RODS92Z's Avatar
I believe the wiring harness runs along the back of the motor against the fire wall and goes into the passenger side by your blower motor. Email me if this isn't what you need.
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
mizz0313
Aug 12, 2015 06:45 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
