Need Help With Cooling Fan Wiring
Old Jul 22, 2001 | 10:03 PM
David Culpepper's Avatar
I have a '91 Z28 and one of the cooling fans doesn't come on. I check the fan itself(the motor) and it runs fine. I am just not getting power to it. I checked all the fuses and they were fine. I think it might the relay. My question is where are the relays for the fans located? And other than a broke wire is there any other possible causes, if so what are they? Any help would be much appreciated.
Old Jul 22, 2001 | 10:40 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
The relays are typically located on the driver's side firewall, close to the hood hinge. There are 3 relays all in the same location. I had the same problem with my T/A and all that was wrong was the temp. sensor located between the #6 and #8 spark plugs.
Chris G
91 TA WS6
Old Jul 22, 2001 | 10:43 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I had a similar problem with my power door locks. Turns out the wire running to the relay was loose and was making a poor connection... that might be the solution to your cooling fan problem. This site may help you out: http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Old Jul 22, 2001 | 11:29 PM
Thanks for the help. I am going to check those things tom.
Old Aug 2, 2001 | 11:08 PM
ullearn's Avatar
I am having exact same problem except I have checked everything so far keep me informed if you learn anything and I will do the same for you
ullearn@hotmail.com
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
