Wont go...
Old Aug 26, 2002 | 02:33 AM
92FirebirdV6's Avatar
Wont go...
okay i gotta 92 firebird w/ a V6 MPInjection, and the problem im running into is that it idles fine, but when i drive it and put a load on it like if im trying to go up a hill it bogs out and sometimes back fires and looses alot of power, i have changed the following parts,
Cap/Rotor/Plugs/Wires/O2 Sensor.
I did a fuel pressure test which seems to be normal, some have suggested a plugged cat. any ideas? im trying to get this up and running so i can use it as my daily driver and my 70 camaro as my weekend car, and besides if it sits to long the city wants to tow it.
Old Aug 28, 2002 | 02:34 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like the timing is off. Have you checked the base timing (bypass connector disconnected)? The timing @ idle with the bypass connector connected?
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
classicgm
Oct 16, 2004 11:36 AM
SchwarzCamaroRS
Apr 1, 2004 12:45 AM
palric
Dec 15, 2002 08:30 PM
