tach needle bounces at 3000-3500 rpm
Old Aug 7, 2001 | 11:40 AM
FlaTToPP69's Avatar
cruising in 4th at approximately 70-75mph the tach needle will read between 3000-3500rpm and will start to jump erratically any suggestion stock ignition system. wondering if possible bad ground or faulty distributor any suggestions
Old Aug 7, 2001 | 09:32 PM
speedlvr's Avatar
see if your coil wires are close to any of the spark plug wires. that can do it.
Old Aug 9, 2001 | 08:18 AM
FlaTToPP69's Avatar
no i checkeds that already. made sure to do that in the first place thanks for the thought though. i think i am going to double check the wires and there resistance. what's really wierd is that the fast i go and the higher the rpm such as 3500-5000rpm the needle twitches even more. i don't know if its even related but some times the temp guage will twitch slightly too
junior419
Apr 7, 2025 11:35 AM
RedLeader289
Sep 23, 2015 06:50 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
