RPM gauge
Old Aug 26, 2002 | 07:21 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
RPM gauge
Hey guys. Ive got a problem and am having a tough time with fixing it or getting info. I drive a 1991 Z28 355cid auto. I am having trouble with the RPM gauge which started on Friday. Sometimes the gauge will sit at 0 even when Im driving. Other times it bounces around like a mad man even when Im cruising at a constant speed. The car runs great/no drivability problems but that gauge does the spiking thing. Sometimes it runs normal. It did it today so I stop the car and put her in park--> gauge slams to 0 I push all the wires near the coil/distributor and the gauge starts bouncing then normal and then bouncing. My ignition set up is MSD distributor/MSD coil/MSD 6AL and Taylor wires. Any ideas?????
Old Aug 26, 2002 | 08:07 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Sounds like your tachometer (not RPM gauge) is on it's way to the scrap yard.
There's a little motor in there that you need to replace. You can get it from any parts store or even a scrap yard.
AJ
Old Aug 26, 2002 | 09:08 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
How hard is that to change? I have had the cluster out before but I thought that it was a sealed unit with just the 2 electricall plugs.
Old Aug 29, 2002 | 08:27 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
whats wierd is that my tach i had a problem with for like 3 weeks straight, a couple months back, and it would do things like be stuck at about 1500 or so after start up and stay there for anywhere from a couple minutes, to the entire time engne was running, when it did it.
it hasnt done it for a couple months now and seems fine now,
wierd..
good luck
Old Sep 2, 2002 | 12:48 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Anyone....
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
