Blinker fuse blowing and radio going out at idle? Common problems?
Old Aug 11, 2001 | 01:10 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Well the turn signal fuse has been plowing every ten or so turns after I replace the fuse, I went up to a 25 amp and it still blew. Any higher and I'm afraid I'll burn a wire. Also my radio has been cutting out on me ONLY WHEN THE CAR IS STARTED and at idle. Could the problem be voltage regulation or are they even related?
Matt
1984 Camaro Z28
-'78 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM Air gap intake, ACCEL plugs & wires, 14" K&N filter.
-TH350 with Hurst Pro-matic shifter & B&M Street shift kit.
-Audiobahn single 12" Sub powered by Sony Xplode amp, Farenheit 6x9" & 4x6" speakers, with a Sony Xplode headunit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Apr 9, 2016 10:20 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
