Fuel and volt gauge not working
Old Aug 13, 2001 | 01:38 PM
IROCZ89's Avatar
Ok, the fuel gauge is pegged at the top and thte volt guage is pegged to the bottom. I have replaced the entire instrument panel and just the guages. No other gauges are involved. When it first started I could tap the gauges and get them to work now nothing. They went totally to junk after I replaced the instrument panel. I put the original back and nada. Nothing seems to fix the problem.
Has anybody heard of this type of problem before? Have any of you had this problem before? My next step is to trace the wires and look for a short.
Thanks,
Phil
89 IROC 5.0 TBI
Soon to be a 5.0 TPI, with a disk rear.
Old Aug 14, 2001 | 03:34 PM
IROCZ89's Avatar
wtt
Old Aug 15, 2001 | 04:53 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
I'm having the same problem with my fuel gauge. Gonna post a question bout it so maybe somebody will help. The gauge worked fine, then one day, it didn't work and was down in between empty and 1/4 tank. Then had a new fuel filter put on and it pegged to the top. So, i'm thinking maybe sending unit or wire is grounding out. Mechanic buddy says sending units rarely go out, and said check my wiring. Dunno if this helps you out, but may give you an idea or something.
86' IROC-Z
5.0L TPI
Spohn panhard bar and LCA's
Old Aug 16, 2001 | 10:27 AM
IROCZ89's Avatar
Thanks,
Looks like I will be into the never ending wire trace.
Phil
89 IROC 5.0 TBI
Old Aug 17, 2001 | 10:31 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I had the same problem with my car. It turned out to be a loose wire in the cargo area (to be more specific the harness that is in the left (driver's side) corner of the back). Try lifting the plastic and make sure all the wires are connected.
Not sure about the volts. Maybe a loose wire too.
Hope this helps,
Matt
Matt
1984 Camaro Z28 - Black w/ Grey int.
Best 1/4 - 13.6 (5-speed) & 14.0 (Auto & 2.73!)
-'78 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM Air gap intake, ACCEL plugs & wires, 14" Accel filter, Homemade Cold Air Indctn.
-TH350 with Hurst Pro-matic shifter & B&M Street shift kit.
-Audiobahn single 12" Sub powered by Sony Xplode amp, Farenheit 6x9" & 4x6" speakers, with a Sony Xplode headunit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
Comming Soon:
3.73's, Flowmaster, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
