True or not true?
Old Aug 20, 2001 | 05:58 PM
91RSconv's Avatar
True or not true?
My mechanic friend said that my 91 tbi gives more gas when the car is cold and less as it heats up or something like this. He said there is a way to hook up a switch to keep the cold start fuel pressure on when you want it on. Is there any truth to this? My car always feels alot faster when I first fire it up
91' red RS convert.
71,000 miles
89' IROC hood
red Z-28 16" rims
potenza re730's
MSD ignition
MSD coil
K&N fiter
350 ported polished heads
hypertech chip
flowmaster 40 series cat-back
Old Aug 20, 2001 | 09:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You can unplug the CTS (coolant temp sensor) and jump the connector terminals with a 640 ohm resistor causing the ECM to 'think' the car is only running about 145-150°. This fooling the ECM into 'thinking' it's not quite warmed up yet will let it allow more advance & fuel.
Words of caution, some cars rely on the CTS to turn the fan on, and detonation is more likely to occur (even more if you use low test/octane gas) since the ECM on percives the engine as cold when realistically, it's at operating temp.
The mind is like a parachute, it only works when its open
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
