Temp Gauge Sensor
Old Aug 20, 2001 | 01:41 PM
quattroboy's Avatar
Temp Gauge Sensor
Can anybody tell me where the Temp Gage Sensor is on my 86 305 Iroc Z (my temp gage isn't working) and what the two sensors on top of the Thermostat Housing are for? one as black/yellow wires.Any info gratefully received.
Old Aug 20, 2001 | 04:50 PM
Rice_Cooker_'88's Avatar
as far as i know, the sending unit for the temp gauge is between the #1 and #3 spark plugs. don't know about the wires on the t stat housing. i don't have them.
'88 CAMARO 305
OPEN AIR ELEMENT
FLOWMASTER CAT BACK EXHAUST
COMPUTER CHIP
HYPERTECH 160* THERMO.
Old Aug 20, 2001 | 09:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
LG4 (carb'd)? The sensor w/the wires is the water temp sensor for the ECM & the other, I believe, is some sort of temp controlled vacuum valve for the EVAP canister.
The mind is like a parachute, it only works when its open
Old Aug 21, 2001 | 09:22 AM
ATOMonkey's Avatar
The temp sensor for the gauges should be on the block between on the 1 &3 cyl. on the drivers side. It's a one wire slotted connector.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
85Special
Sep 3, 2015 04:21 PM
