Hot wires
Old Aug 21, 2001 | 10:46 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Hot wires
I hooked up a set of aftermarket driving light on my 83 bird, the other day i noticed that the wires that connect to the switch get hot whe the lights are on. Why is this? How can I fix the problem? I'm thinking about putting the switch in the dash or on the cenert consel, I dont want the heat to melt anything, or burn some thing.
Robert
Chevy 2.8L 60° V6
Mods:
•K&N Filter Lid
•87 Formula Hood
•Bosch Platinum +4
•Hi-Flo CatCo CAT
•Flowmaster 80 Series Muffler
•83 Trans Am 15x7 Turbo Fin Wheels
•B.F.Goodrich Radial T/A 225/60-15
•Chevy 2.8L Heddman Headers (Going on soon)
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Aug 21, 2001 | 11:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Resistance through the wire causes the heat. Generally low budget driving lights (and probaly even more expensive too,,) use a single thin 18ga wire to supply power to both lights. While the fuse & the switch, have no problem handling this, the wire is just barely large enough to keep from catching fire. The best solution is getting a relay to power the lights. A mildly cheaper (but safer) solution is getting heavier gauge wire, and running 2 wires off the switch to each light.
The mind is like a parachute, it only works when its open
Old Aug 21, 2001 | 11:13 PM
fiream's Avatar
Engine: 400HP 350
i'm using a 16ga wire now. my buddie said it may be a bad ground?
Old Aug 21, 2001 | 11:23 PM
deadbird's Avatar
Engine: TPI 305/ v6
A single 16 ga still isn't real thick wire for powering 2 35-55watt lamps. Ground could be a possibility, I've always grounded the lamps under the nut of the mount (since I bolt them to the impact bar), closer is better. Make sure you have a good chassis ground as well (lead from - terminal to the frame,, should have one already). There will always be some degree of warmth in the wire though regardless. I'm getting ready to put a relay in for my driving lights.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
86IROC112
Aug 21, 2015 07:20 PM
stalkier
Aug 21, 2015 01:54 AM
