2 alternators, will it work and would it help?
Old Aug 22, 2001 | 02:01 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Hey I was wondering if anyone has or has heard of using 2 alternators for more power to ignition, stereo, windows, etc etc... ? If so I would assume that you would wire it in parallel to the other alternator? this would also create more reliability I would think since both alternators would not have to work as hard, creating less heat and ending up with longer life. Im sure some would say how to mount it? well I put a paxton on mine and didnt like the idea of having the alternator mounted below the P/S pump (incase it ever leakes, oil in a hot electrical environment can end up with a lot of problems) I had removed my air pump when I put the headers on, so I mounted the alternator there, its been there almost 8 months and many many miles and no problems once I got it mounted to where the fan wouldnt hit. Im taking the paxton off so I would put another alt where the stock one went.
So once again would this help, work or would it cause more problems with having to try to regulate or overcharge?
thanks
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. Found a guy who can build me a ford 9" (yep sorry guys) for less than 500 then comes all the goodies such as disk brakes so on and so on, will it ever end?? I hope not!!
Old Aug 22, 2001 | 03:44 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Do a search-this topic was brought up not too long ago...
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
dutch930
Sep 11, 2015 06:58 AM
Navy8125
Aug 22, 2015 07:13 PM
