Help my Alt. is acting very funny.
Old Aug 23, 2001 | 09:17 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I have 1987 GTA that has a 350 TPI, that had a engine fire. Ok now it runs. The trouble is that when I rev it up like to what it sounds like is 4000 rpms, (the tach is maxed out at 7000 rpms?)it also has the digital dash. the alt quits charging. The lights dimm and the guage drops. But when I lower the rpms it starts charging again. Now this is a brand new remanufactored unit (new means never been used before I bolted it on the car). THe wiring harness is out of a 87 IROC 350 TPI. Is the alt bad or the wiring, or by some weard chance Am I REALLY getting 7000 rpms? I highly doubt it Because my IROC sounds the same at 4000 RPMS.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Old Aug 25, 2001 | 10:05 PM
AaronIROCZ's Avatar
ANYBODY!?!?!?!?!?!?!?
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
Old Aug 25, 2001 | 11:28 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I don't know if this will help or not but here's an alt. wire diag. for an 85 TPI camaro
http://www.geocities.com/vtcamaro/Pi...rams/pg137.jpg
I've never personally seen a dig. dash yet but I've seen quite a few complaints about them before on here.
TPI (along w/a stock mototr) will not willingly/easily goto 7k rpm. The tach gets its signal from the white wire off the coil I believe. Hope that is of some use.
The mind is like a parachute, it only works when its open
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
