Which wire is for the horn?
Old Aug 26, 2001 | 09:15 PM
Hulk0202's Avatar
I want to connect my horn to a button elsewhere. The problem is that the original wire spins withe the wheel, and this is causing problems. Can anyone tell me what color the wire is that goes to the ground for the horn. Id like to splice in at the column. Thanks for the help.
Old Aug 26, 2001 | 10:38 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I think that the wire is yellow. However, this is the "hot" wire; the horn is grounded to the metal on the column itself.
1986 Camaro IROC-Z
Code 23 Paint ("IROC Blue")
305 TPI w/ Auto Tranny
Grant GT Steering Wheel
New A/C Motor!
Old Aug 26, 2001 | 10:47 PM
Hulk0202's Avatar
Has anyone hooked up a switch for the horn? How do you do it?
Old Aug 26, 2001 | 11:57 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
From the horn relay, there should be a black wire going to the steering column. It completes the ground for the relay using the horn button.
Splice this (black) wire to a switch, ground the other end of the switch.
The mind is like a parachute, it only works when its open
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
