Slight Problem With MSD 6A
Old Aug 22, 2001 | 09:30 PM
JR4444's Avatar
I recently put in a 6A Box in my 88' Formula 350 and when I hit about 4000 RPM's my tach goes down to 0 RPM's untill It shifts. And then It reads it fine. Thanks
Old Aug 23, 2001 | 01:53 PM
definitive1's Avatar
Mine did the exact same thing. There is something in the directions about removing some filter on the factory tach wire, but i didnt bother because it gave me a reason to buy an aftermarket tach which looks alot better.
Old Aug 27, 2001 | 01:04 PM
MSD tech's Avatar
Your Formula probably does not have the tach filter. The 87-89 generally did not. Check though, this will be with in 1-1 1/2 feet of the coil on the white wire of the factory harness. It is a small 1x1 black box with a white wire going in and out and a black ground wire. Basically unplug the whites and hook them together eliminating the filter. If this is not found you can get the tach adapter part number 8910 to fix the problem.
Thanks,
Joe
MSD tech
stalkier
Dec 6, 2015 11:25 PM
db057
Sep 4, 2015 07:57 AM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
