Blower motor
Old Aug 3, 2001 | 11:21 AM
Tonyrodz's Avatar
Transmission: auto
Blower motor
I'm still in the process of trying to get my T/A together--now my blower motor won't turn on! I jumped a hot lead to the blower motor itself--runs fine--what wires are supposed to be hot? I see the big purple wire--is it hot all the time? Anyone have any ideas why it wouldn't be working?
Complete harness was swapped over-car is an 86-donor was an 89-both tpi's. I think the blower motor harness was seperate from the engine harness-don't remember tho.
Anybody?
Old Aug 3, 2001 | 11:24 PM
RODS92Z's Avatar
May be your resistor.
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
Old Aug 4, 2001 | 09:56 AM
Tonyrodz's Avatar
Transmission: auto
Where would the resistor be located?
Old Aug 4, 2001 | 05:55 PM
87tpi420's Avatar
it should me in your blower motor housing, to the right side of the blower itself with a connector with 3 or 4 wires and two small screws holding it in
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Aug 4, 2001 | 11:41 PM
Tonyrodz's Avatar
Transmission: auto
Ok, I know where that baby is!
I guess if it's bad I'll be able to tell?
Old Aug 5, 2001 | 10:45 AM
87tpi420's Avatar
i dont know how to check it but i know it only costs about ten dollars at chevy dealer. maybe 15 . check just coming out of plug with a volt meter would be my guess, with switch on low one wire should have low voltage fan on medium, wire should have higher voltage etc. or just check wire in and if there is power and nothing coming out...that is the culprit!
Old Aug 5, 2001 | 12:23 PM
Tonyrodz's Avatar
Transmission: auto
Will do--definitely will check it! As usual I have a spare one of those too!
Old Aug 5, 2001 | 03:34 PM
Tonyrodz's Avatar
Transmission: auto
Ok, I changed out that part for a known good one--still nothing! Fuse checks ok. There isn't any power coming from any of the wires that goes into that relay--where should I go from there? Need a few ideas. Thanks.
Old Aug 5, 2001 | 09:37 PM
Tonyrodz's Avatar
Transmission: auto
Anybody??
Old Aug 27, 2001 | 02:56 PM
Tonyrodz's Avatar
Transmission: auto
Still can't get it to work. Does anyone know what color wire should be hot? Under the hood and in the car?
Also is there a way to rig it to work?
I just want the thing to blow.
Old Aug 27, 2001 | 06:18 PM
87tpi420's Avatar
i am lost now, but you could rig a switch into your car. i have done it on more than one occasion. i used an old cigarette lighter cord and when i wanted to turn on i would just push it in and presto. cheap temporary fix.
http://people.ne.mediaone.net/gdm
Old Aug 27, 2001 | 06:32 PM
Tonyrodz's Avatar
Transmission: auto
What would be the best way to do it?
From under the hood or inside the pod?
Which color wire should I splice into??
[This message has been edited by Tonyrodz (edited August 27, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
