electric fan issues
Old Aug 28, 2001 | 01:55 PM
iroc5speed's Avatar
electric fan issues
A few days ago I was driving around and my car's temps got up to around 260 degrees. This has happened before, so I didn't freak out, but I knew something was wrong(I wen through a lot before replacing my entire cooling system). I checked the fan and it wan't running. The fuse was blown, so I changed it. I then put in 2 more fuses and they blew instantly. I even tried a 30 amp fuse, which also blew. Somebody help me, I don't know too much about electrical system failures.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
Old Aug 28, 2001 | 01:59 PM
Desert86Roc's Avatar
You need a new fan motor....this is common. Sometimes they just go out, and dont blow a fuse...other times they short and blow em.
You can pick up a new motor for about $29 from Autozone with a lifetime warranty....I have 2 of them that probably get replaced every other year because I use them so much (they do have a limited lifespan).
M.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
Old Aug 28, 2001 | 02:53 PM
iroc5speed's Avatar
I just replaced the fan motor with one that has a lifetime guarentee about 2 months ago, and I've only driven the car about 1000 miles since. So I don;t think that the motor is bad. It came on for a few seconds with the 30 amp fuse, then the fuse blew(you can see where the metal burned though.) Any other suggestions
Old Aug 29, 2001 | 08:11 AM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Check for a short to ground on the wires which connect to the fan.
First unplug the fan motor. Then use an Ohms meter (or DVM set on Ohms) to check from a good ground to each of the (two) terminals which plug into the fan. One of them should go to ground, the other should not. If they both show continuity to ground then that is your problem.
If that is the problem then look for a melted area of the power wire which goes from the relay to the fan. If this wire is shorted to ground (or melted to the other wire going to the fan, which will also cause a short to ground) then repair this wire.
Old Sep 1, 2001 | 05:11 PM
iroc5speed's Avatar
I found a short in one of the wires. There was a small cut in it(no clue how it got there) Spliced out that part, and everything is working great. Thanks guys for all your help!
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
"speed kills. buy a f@&d, live forever."
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
mizz0313
Aug 12, 2015 06:45 AM
