tail light switch
Old Sep 1, 2001 | 02:05 AM
i8urrice's Avatar
tail light switch
what steps would i need to take to put Trans Am tail lights on my Formula? i know something has to be changed b/c on a formula, it has separate lights for the yellow turn signals....the Trans Am's turn signals also work from the brake lights and running lights......what would i have to do to make it work?
Old Sep 2, 2001 | 03:00 AM
AmorgetRS's Avatar
I have done this and it really depends on if you want it to look like a TA or not. For a start I just put the tail and brake lights in the center two, then the turn on the outer edge, replacing the stock turn signal bulb socket with one from a 89 or so TA. Worked fine, and most of the guys do that. But if you want real TA tail lights it is a little more complicated.
If you want a full detail on the TA tail light looking TAish you can e-mail me, because if you don't care then I don't really want to type it all out
Douglas
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
Pilotrick50
Sep 2, 2015 12:48 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
