Atten: 87-88 GTA owners
Old Aug 25, 2001 | 09:01 AM
Brent's Avatar
I'm trying to put my 87 GTA's cooling fan harness/relays back to stock. The hack that owned the car before me cut the factory harness and relays out.
I have the Helm manual for my car and it doesn't have a nice picture of the harness routing and none of the junkyards have a dual fan firebird to look at. So.... I'm not sure what all is missing.
Would anyone have pictures of the fan relay/harness setup they could post or email me? There is also a 6 pin inline weatherpak that nothing is plugged into next to the aircleaner. If so I'd be really grateful.
Old Aug 25, 2001 | 10:08 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I think that on my 87 GTA the harness from the fans plug in the pin plug. I also have a 89 IROC I think that it is the same. I can double check the IROC but not the GTA, because it is at the body shop getting painted. Ill let you know.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Old Aug 26, 2001 | 05:47 PM
Brent's Avatar
Thanks, I appreciate it.
Old Sep 2, 2001 | 12:44 PM
Brent's Avatar
BTT
Old Sep 2, 2001 | 04:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Still no luck with a diagram huh ?
Try this http://www.deadbird.org/tech/fan.gif
For the passenger side fan, The green/white wire goes to the fan switch in the passenger side head between the #5 & #7 cyls instead of to the ECM.
The weatherpack was part of the OEM wiring to supply power to the relays & to the fans.
GM themselves did a pretty sad job of running the wires IMO. You might just be better off starting at the battery.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 16, 2001).]
Old Sep 2, 2001 | 06:33 PM
Brent's Avatar
Thanks for the diagram, but I already have that.
What I need are pics of the actual relays and harness in the car, so I can tell what is missing.
Old Sep 2, 2001 | 07:49 PM
deadbird's Avatar
Engine: TPI 305/ v6
This is all there is to the fan harness (not in the same location as shown keep in mind),,,
http://www.deadbird.org/tech/fans.jpg
2 relays, the worthless 5-6 pin plug (lower corner of pic),the fusable link (about 6" off the + batt terminal, no pic, mine's been gone for awhile now), the fuse holder(goes on the fusable link), and the sensor in the pass side head.
Hotrodboba400
Dec 10, 2019 07:07 PM
84 TA NV
Sep 6, 2015 08:02 PM
machinist21
Sep 5, 2015 03:03 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
