power to coil
power to coil
ok i hacked my stock harness out and put dfi in it. problem i have it this i have a pink wire coming out of the firewall next to brake booster.. it is cut but i know it goes to the coil. it is ignition 12v. but the white wire on the coil i am lost at to where it goes. can i just put it to chasis ground? or does it have to go somewhere specific?
help is appreciated as i am nearing the end and want to button up everything
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The white wire goes to the Tach., I guess you could just ground it (don't based just on that tho).
Hear's a diagram for the tach on an 85 camaro
http://www.geocities.com/vtcamaro/Pi...rams/pg174.jpg
You'll have to make your own conclusion from that. The wire diagram I have doesn't show a tach in the car but the wiring going to where it would be from the coil, it just terminates at the cluster connection. Guess that's not much help really but, at least you have a nice diagram to look at
The mind is like a parachute, it only works when its open
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
sailtexas186548
Aug 24, 2015 10:11 PM
