I was told that i have to wire it to the ecm for a more accurate reading..... because of there only being one wire to the o2. anyone have any suggestions?
I've installed that guage in my RS, I hooked the signal wire with a wire tap to the Purple wire (D7) at the ecm. Using a wire tap keeps the original O2 wire intact, it just cuts the insulation a bit to the bare wire.. works great.. Along with the guage there are two other wires.. a Red one & black one.. I taped the red wire in with the power wire from the guages fuse, but make sure that you put a fuse holder between the guage and the power wire off the guage fuse. The Autometer guage requires a 5amp fuse, I used a 3amp, with no problems.. Since the guages fuse is 10amps... Then for the black wire I wanted to ground it with the dash ground, but didn't find it.. so for now I wired in a ground with a group of wires under the dash, just to the right of the fuse box. Hope this helps..
89 RS Camaro, LO3 305 TBI
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
That's basically what I did too, just to confirm that...it's not that bad, I just had to test all the purple wires because I didn't have an accurate schematic. :\
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Moroso Blue Max plug wires
Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Performance mods
NOS (125 HP shot)
Hedman headers
MSD 6A ignition
LT1 camshaft
3.42 rear axle
Transgo shift kit
Torquer heads
Audio
QLogic sealed box
Other
180* thermostat
Window Tint
i should be installing it today or tomorrow thanks for the input guys..........
if anyone has anything different to add please let me know!
thanks
thanks
