lost connector?
Old Sep 10, 2001 | 10:44 PM
AfootVoyager's Avatar
lost connector?
ok here it is...i have a connector under the dash with a thick yellow wire and a thick purple wire....i know that the other end goes to the neutral safety switch under the shifter in the console...but where does the end under the dash go...??please help with this one i am tired of starting my car with a toggle switch!!
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
plain firebird nose(for better engine cooling)
T-Tops, pwr everything
been to about 140mph
Old Sep 11, 2001 | 02:27 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
On a wiring diagam,, I can't find anywhere it would plug into.
The wires either go into a neutral safety switch (where you mentioned on the shifter) or a clutch switch.
The purple wire comes in from the starter, routes thru the switch (either) and goes out as the yellow wire to the ignition switch.
Do you crank the car having the switch in the end of the plug & flipping it or do you flip the switch & then start the car the normal way ?
The mind is like a parachute, it only works when its open
Old Sep 11, 2001 | 05:09 PM
i have the toggle switch where the neutral safety switch was...right now i have a 12v source(cigarette lighter) going thru the switch to the purple wire...if i connect the yellow to the purple then the starter cranks whether or not the key is on...need to know where the under dash connection goes
Old Sep 12, 2001 | 01:10 AM
deadbird's Avatar
Engine: TPI 305/ v6
What color is the connector ? On my bird (5 speed) the connector(blue) goes to the clutch switch then into the harness.
If I have time, I'll check my camaro(auto) later today
[This message has been edited by deadbird (edited September 11, 2001).]
Old Sep 12, 2001 | 08:13 PM
i think the connector is blue....however i have no clutch....auto tranny!
Old Sep 14, 2001 | 04:10 PM
IROC&ROLL
Guest
Posts: n/a
The yellow wire goes from the ignition switch to the p/n switch. The purple wire goes from the p/n switch to the starter. The only connector under the dash should be connected to the ignition switch. The ignition switch itself is located at the base of the steering column, not where the ignition lock cylinder is. There is linkage that runs from the lock cylinder to the switch.
If you are getting lights, accessories, etc. with the ignition switch in the run position, but you are not getting power on the yellow wire when the switch is turned to start, your ignition switch is probably bad or there is possibly a mechanical problem with the lock cylinder/linkage.
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
3.8TransAM
Sep 27, 2015 08:37 PM
