Is the Choke Relay necessary on a non cc set-up?
Old Sep 3, 2001 | 09:25 PM
Changa2's Avatar
I pulled all the wires from the pass. side harness route, so there are no more cc controlls.
I did re-install the Choke Relay as I have a 750 Holley with an electric choke. I'm not so sure that I got it wired correctly as I have only 2 Volts at the + side of the choke.
The engine is new and I haven't started it yet but with just the key in the on position what voltage should I see? What is the basic function of the relay and do I even need it?
87 Camaro with 700R4 and 3.23 posi, impatiently awaiting 383cid, 4-bolt #010, Int. Balanced Eagle crank assembly, 4340 crank and H-Bean 6.0 rods with SRP flat tops.
DART IE 200/72cc heads (10:1 C/R) with Harland Sharp 1.5 full rockers and Guide Plates
Comp Cams XE274H (230/236 .487/.490 110LSA 1,800-6,000 RPM).
Edelbrock RPM manifold with 750 (Vac/Electric) Holley.
MSD Pro-Billet (Vac) with 6AL box.
My best guess (Dyno 2000) is about 400HP and 430TQ??
Old Sep 4, 2001 | 04:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The choke relay turns power to the choke off when the engine isn't running with the key in the on position.
Old Sep 14, 2001 | 04:26 PM
qazd's Avatar
I have the same setup on my 87 Z, I deleted my harness, and ran the choke directly from the carb to a switch panel under my steering column. I have mo relay, and choke is working fine-Good luck
'87 Z-28 305,Edelbrock 600 cfm, stock 700-r4 terribly slow
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
