The blinker...IT DOESN'T BLINK! =O
Old Sep 10, 2001 | 02:56 AM
BahamutRS's Avatar
Yeah, my left blinker won't blink. At first I thought it was because the sidemarker was out; but I replaced both sides with 168 bulbs for a bit brighter light..anyways, all the lights go on..front..side...tail...but it doesn't blink. The right blinker works FINE. This can't be a fuse, can it? I was then thinking a wire..but I'm not tearing the car up to fix this...but I need to..ugh....help, anyone?
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Moroso Blue Max plug wires
Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Sep 10, 2001 | 08:06 AM
diesel's Avatar
That happened to me as well (on a trans am). IT was the front turn signal light, the sidemarker was bad. On mine it was a 1157NA bulb (this is a 2 element bulb). The signal indicator would blink on right, solid on for left and would both blink on flasher.
Try swapping the front and rear turn signal bulbs (one at a time) from side to side and see if the problems follows.
Old Sep 11, 2001 | 11:17 PM
88camaro's Avatar
ok, i have the same problem when i turn on the hazzard light everything blinks but when i try to turn on the right side turn signal it doesnt blink............
HELP
Old Sep 14, 2001 | 03:18 PM
dbarkley's Avatar
Car: 1985 Trans Am
Transmission: 4spd auto
88camaro... sounds like a wire
Old Sep 14, 2001 | 04:38 PM
IROC&ROLL
Guest
Posts: n/a
Check my reply to this post: https://www.thirdgen.org/messgboard/...ML/002403.html
Old Sep 15, 2001 | 02:51 PM
Tyler-88's Avatar
sounds like you got a burnt out bulb.
gta892000
Aug 11, 2019 11:16 AM
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Giocio
Oct 1, 2015 12:20 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
corey8084
Sep 17, 2015 02:56 PM
