Need a wiring harness for tpi!!!
Old Sep 13, 2001 | 12:42 PM
jred_82's Avatar
I recently swapped 305 tbi for 350. I used original intake and throttle body but want to
upgrade to tpi. Is there a wiring harness available for this conversion? Also what modifications need to be done with the computer? Any and all suggestions welcome.
Old Sep 13, 2001 | 04:08 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You will need a TPI ECM, harness, and possibly a fuel pump, to do the swap.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Sep 14, 2001 | 10:05 AM
jred_82's Avatar
Thanks, is there an aftermarket wiring harness to due the trick or do I have to go to the junk yard and get one? I thought Painless Wiring might have something but I'm not for sure. If anyone else has done this swap let me know.
Old Sep 14, 2001 | 04:44 PM
hotpowerandperf's Avatar
Painless sells a MAF (60102) and SD(60103) version of the tpi harness. I have seen prices as low as $281 for the MAF Harness and $270 for the SD. The computer is 1227165 for MAF and 1227730 for SD. Pick one of these up from the pile at a yard. You also need a VATS(anti-theft) module or a chip with the VATS bypassed. You must change to a high pressure pump and hook up the fuel lines. You will need lots of o-rings and gaskets for TPI rebuild. You also may require new injectors. FMS 24# are made by Bosch and work well.
If you have more ? just ask.
John
Heart of Texas Power and Performance
Old Sep 17, 2001 | 10:07 AM
jred_82's Avatar
Thanks again, that should do it for now I guess. I appreciate all the help, it was much needed.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
