Power windows slowing down
Old Sep 10, 2001 | 12:19 PM
Lexxicon_2001's Avatar
Anybody know what causes this????
Thanx
Lexx
Old Sep 10, 2001 | 01:51 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Lack of lubrication in the mechanism. If you dare to venture inside the door, just lubricate the tracks with some grease.
The motor does not loose speed so this is the only thing that will slow it down.
Old Sep 10, 2001 | 05:04 PM
Thanx OZ.
I had the door panels almost off and then was stymied by something holding the panel securely in place up by the window.
Dare I go back and try again??
LOL
Lexx
Old Sep 11, 2001 | 01:42 AM
Hot damn it worked!!!!!!
Thanx for the tip.
Lexx
Old Sep 19, 2001 | 11:42 PM
Just wanted to let everybody know that I replaced the power window motor using the directions in the article
Power windows 101
https://www.thirdgen.org/newdesign/t...rwindows.shtml
What a godsend. The shops I called wanted between 200 and 300 bucks to do this job.
Man am I glad I found this forum.
Thanx
Lexx
Old Sep 19, 2001 | 11:50 PM
zee28's Avatar
Car: 86 iroc
What kinda grease should you use?
~white~86 IROC-Z
Old Sep 19, 2001 | 11:57 PM
Lithium grease. I bought mine at Walmart.
The grease idea worked for the passenger window (maybe buying a litle time) but the driver window motor was shot.
Lexx
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
