Cooling Fan
Old Sep 20, 2001 | 07:27 PM
85roc's Avatar
Cooling Fan
The cooling fan on my 85 IROC 305 TPI has to have the wires put together to run. To stop it from running I have to disconnect the wires. I know the fan should come on automatically when the motor gets hot enough. Something must be broken? Can you tell me where the piece is that makes the fan come on? What is it called?
Thanks, Tom
Old Sep 20, 2001 | 09:11 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You might want to chech thru the fuses under the dash. The relay for the fan is powered by the fuse panel (powered, key on only) and the ground is ECM controlled. If you haven't messed with wiring,, check the fuses.
The mind is like a parachute, it only works when its open
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
