87 TA Headlight Relays?????
Old Sep 15, 2001 | 11:26 PM
mtccl's Avatar
How many and where are the headlight relays located on the 87-on two wire headlight motor systems? (Headlights won't pop up. Motors are fine. Replaced the 4 prong relay next to battery. Opened motors...it's not the bearings.)
1987 Trans Am 305TPI
Old Sep 16, 2001 | 12:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Looks like this.
It's on the drivers side of the firewall next to the brake booster
The mind is like a parachute, it only works when its open
Old Sep 20, 2001 | 09:10 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Sorry it is not a relay that controls the headlight motors, it is a module. I know this because my 87 GTA had a engine fire and I had a wiring harness out of a 86 TA and it had the relays. I could not get it to work with the 2 wire motors. So I then removed all of the relays, found the nessacary wires and wired up the module. I think it is mounted up by the brake booster like the picture shows in the last reply. Mine was gone.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Old Sep 20, 2001 | 09:14 PM
deadbird's Avatar
Engine: TPI 305/ v6
Aaron is correct in that it's not a relay (which I forgot to mention, thanks Aaron). One thing tho,, don't expect to find yours where mine is (which is inside the car under the dash). The pic was only to show what it looked like.
thunder57
Nov 7, 2015 02:28 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
