Cruise Control - incorrect functioning
Old Sep 19, 2001 | 07:44 PM
Adam89F's Avatar
Hey guys.
I had my tumbler fixed a while ago and ever since the cruise control doen't work properly.
Sliding the lever to R/A to "set" the speed doesn't work anymore. Now I have to press and hold the button on the end.
Also moving the lever to R/A to "Resume" or "Accelerate" doesn't work any more.
What is wrong? What do I look for?
Any help is welcome (novice).
Thankx
Old Sep 21, 2001 | 02:27 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Sliding the switch to R/A shouldn't set the speed anyways,, that's what the button is there for. If you turn the cruise on & push it to R/A to set the cruise, there is no previous set speed for it to resume too.
(I'm sure you know this but,,) For your car to resume it's cruise you have to have set the cruise before you came to the stop you're wanting to resume to.
Since the car does set cruise (I assume from what your said), if you press the switch over to the R/A does it pick up any speed (while you are at a set cruise)?
The mind is like a parachute, it only works when its open
Old Sep 22, 2001 | 12:24 PM
Adam89F's Avatar
Hey deadbird
When the cruise is set/on and then I hit the brakes to slow down, sliding the lever over to R/A does nothing (or if I just slide it over while "cruise"ing)
I could have swore that before I could set the cruise by sliding the lever.....maybe my memory is going.
Old Sep 23, 2001 | 10:22 AM
IROC&ROLL
Guest
Posts: n/a
I've got the same problem on my wifes car. It is the R/A part of the switch that is bad. These don't use plain open or closed contacts; they use resistance. The whole turn signal lever must be replaced, but it is very simple. Just unplug the cable from the CC switch to column then pull straight out on the lever.
BTW, your memory is correct. Pushing the switch to R/A will set the cruise. It took me a while to figure out why when I sometimes hit the blinkers that the car would suddenly go into cruise (which can be alarming as you are normally decelerating before making a turn). I knew I wasn't pressing the set button on the end.
Old Sep 23, 2001 | 11:14 PM
Adam89F's Avatar
Sweet.
I can now justifty buying a new lever not just for the fading lettering.
BTW, I like the white lettering as oppose to the Camaro yelow....sorry guys/gals.
I think they go for like $25 CAN.
Thankx IROC&ROLL
Old Sep 24, 2001 | 06:43 AM
IROC&ROLL
Guest
Posts: n/a
Go to deadbirds collision parts page/steering column (http://www.deadbird.org/diags/partmenu.htm) and look up the 'combo switch' for your particular car. Then go to http://www.gmpartsdirect.com/ and search for your part number. The switch for mine ('87 w/cruise&pulse) was only $10!
Deadbird, thanks for the great page! I can't believe the number of parts that are available, for instance a new Z28 hood for $400. Unfortunately they don't have some of the parts I looked up.
Hotrodboba400
Dec 10, 2019 07:07 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
