Rear Reverse Lights
Old Sep 24, 2001 | 07:10 AM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Rear Reverse Lights
I just bought an 87 z28 a few days ago, and noticed the backup lights only will work if I have the shifter button down and the stick near park. (auto tx) How can I fix it so the lights come on while shifed into reverse.
No License, No z28, No Hope.
Old Sep 24, 2001 | 09:32 AM
mtccl's Avatar
You need to remove your center console to expose the electricals under your shifter. Under there you will find a switch that activates your reverse lights that is activated by the position of your shifter. This switch needs to be adjusted to activate when the gear selector is in reverse. If the switch isn't there in your particular car it is underneath the vehicle mounted on the transmission near the gear selection lever arm. You can adjust it there too. Get a Haynes manual to find the location of the switch.
Vintageracer
Jan 10, 2020 05:33 PM
mizz0313
Aug 12, 2015 06:45 AM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
