Power door locks relay, were is it?
Old Sep 24, 2001 | 01:55 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I just purchased a keyless entry system. Camaros have positive door locks so the keyless entry manual says to wire in 2 relays. Where are the stock 2 relays located so I can use them instead of wiring in 2 more?
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Headers, Rebuilt B&M 700R-4 tranny, Airfoil, K&N's
-- Blue LED backlight Dash
"Just some 17 Year old spending every dollar I make on my car."
Old Sep 24, 2001 | 02:17 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Behind the left hand panel, near where your feet are, when you are sitting in the driver's seat.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Sep 25, 2001 | 11:27 AM
Chris Luongo's Avatar
GM door lock relays are positive trigger. If you keyless entry system only has negative lock/unlock pulses, you'll STILL need two relays just in invert the polarity to positive.
Personally, if that were the case, I would consider not doing business with that company and go buy something different...but if you got a good deal on it...relays are cheap.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
