Brake light won't go off
Old Sep 26, 2001 | 12:39 AM
MidnightZ's Avatar
My passenger side brake light stays on when I turn the car's lights on. It is just extremely bright all the time. Is there anyway to fix this?
Old Sep 26, 2001 | 01:16 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Turn the bulb around or make sure it's fully seated(turned) in the socket.
It's somewhat easy to place the bulb in the socket the wrong way making the brake element light instead of the regular taillamp element. Have someone press the brake pedal as you stand outside of your car w/the lights off & see if it glows dimly. If yes then it's in backwards.
If the brake lights up as normal (lights off) then one of 2 things, the bulb is not fully twisted in the socket (bridging both terminals lighting both elements) or, you have the wrong bulb in there a plain ,(1156 I believe,) turn signal bulb has 1 element & will just light bright.
The mind is like a parachute, it only works when its open
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
