My inline fuel pump relay wiring........?
Old Sep 27, 2001 | 06:19 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
A few questions. Ive got a 30 amp relay. Power wire for the relay goes to the battery, should this be fused? I assume yes. Relay ground to a good ground. Switched source to a fuse tap in fuse box used for previous smaller inline pump. That leaves the two wires from the pump. One is positive(+) it goes to the relay. What about the negative(-) pole offthe pump? Should this go to the other power blade on the relay(it has two)? Or should this be grounded also? I think I am making this more difficult than it has to be. You guys understand what I mean? My real concern is what to do with the ground offthe pump. The other four wires I am fairly certain of. Any help out there?
Old Sep 27, 2001 | 10:08 PM
hotpowerandperf's Avatar
For a standard five pin relay:
Pin marked 86 to ign power. Pin marked 85 to ground. Pin marked 30 to fuse then battery. Pin marked 87 to + side of fuel pump. Ground on fuel pump to ground.
John
Heart of Texas Power and Performance
Old Sep 28, 2001 | 12:21 AM
BLWR PWR's Avatar
Car: 89 IROC
John, thankyou very much for your reply. Cut and dry, to the point. Just what I needed. I got it now. Thank you again.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
