Mystery Harness
Old Sep 27, 2001 | 10:30 AM
duke_mushroom's Avatar
Mystery Harness
My car has fog lights, they aren't hooked up(don't ask me why). Before I knew this I tried to get them to work. I found the switch for them in my center console. This was all back when I first got the car. I checked to see where it should go. In this place (right underneath the lights switch) was a small balck panel. I pried the thing out and found a wiring harness, naturally I thought this was for the fog lights. But it was absolutely impossible to plug the fog light switch into this connector. It's a 6 prong(i think) connector with a bunch of wired going to it. I can't find where it leads. Anyone know anything about this. Also, when I finally checked the actual fog lights, I found the wires to them had just been stuffed up underneath the car but I could not find any other wires that could connect from inside the car. These seem to be store bought fog lights (Blazer or something).Sorry about the length of this, but I just thought I'd like to solve this mystery after 3 years. Thanks.
Old Sep 28, 2001 | 09:39 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
WHat kind of car? Does it have cruise controll? At the base of the steering column there is a 6 hole connector that is used for the cruise. The fog light harness on my 87 GTA was located on the upper most corner of the dash on the driver side.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Old Sep 28, 2001 | 10:48 PM
Sorry about that. It's a 91 RS. It does have cruise control, but I'm not sure about that connector. I've never really taken a close look down there.
Old Mar 5, 2008 | 07:42 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Re: Mystery Harness
Here's another one: bundled in the same harness as my cigarette lighter wires are several coloured wires (two are very heavy) leading to a flat plug with about 6 sockets on it, on the side each one is labelled A, B, C, D, E, F... none of the wires are black... what is this?
Also what is that thing nestled in the body behind the driver's kick panel?
Sorry for the newbie questions
Cheers Tom
KO1
16
Oct 15, 2015 05:00 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
