Headlight Problem...
Old Sep 30, 2001 | 08:00 PM
Winnipeg_Firebird's Avatar
When I turn on my headlights, there is a noticible problem. When the lowbeams are on, The left light is on highbeams, and the right headlight is correct. When you turn the Highbeams on, The left light is on low and the right headlight is correct.
Anyone have any clue what might be causing this? The only thing I can think of might be an internal failure of the High/low beam switch.
Thanks for any help at all!
Old Oct 1, 2001 | 10:18 AM
mtccl's Avatar
It is not an internal failure of the switch. That would give you the same failure in both lights. You literally have crossed wiring somewhere. Have you recently replaced the headlights? Have you replaced the relay? Check to make sure everything is hooked up correctly. Unhook lights and isolate the problem. Then work backwards from there.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
