Blowing Fuse in Tail lights
Old Sep 13, 2002 | 06:00 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey guys I am having a problem with a 89 Iroc Convertible when I turn the headlights on I blow the fuse for the tail lights. I have traced almost everything and I can't find a short. I believe its a 20 amp fuse. I drop in a 30 amp and it will stay on. Could the switch be bad???? Pleas give me some input!!!!!!!
Brian Felts
Old Sep 15, 2002 | 04:33 PM
Kandied91z's Avatar
why would you put a 30 amp if it calls for a 20??
make sure you don't have any accessories ran to that fuse and check all your wiring in your tailights....you may have to remove the bumper cover to get to the main rear harness and check your wiring there.
don't put a larger amp fuse unless it calls for it.
Old Sep 15, 2002 | 11:35 PM
83z4whldsk's Avatar
Track the short down!!!! Last summer at the wreckers there was a Camaro that had been on fire. In it's console were a whole bunch of burned out fuses. The guy just kept changing them. Don't know if he installed larger one finally or just a piece of tinfoil because that part was burned too bad.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
