5.7L TPI memcal in 5.0 TPI car - problems?
Old Sep 15, 2002 | 04:36 AM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
My car's always had a problem with running extremely rough in open loop. Even after countless tune ups, various sensor changes and all sorts of diagnostics on various engine systems, I have yet to find an answer to this mystery. Just for kicks I removed the ECM today and opened it up to find a Hypertech chip in there instead of the stock one . A quick comparison of part numbers on Hypertech's website revealed that the chip is a StreetRunner Chip meant for a 5.7L TPI motor with auto trans. Now my car is actually 5.0L TPI and it used to have auto trans back in the day. It's been a year since I popped in the T5. I know L98 chips will work with LB9 engines though not optimally, but how bad is the difference? Are the symptoms similar to what my car does. Oh yeah not to mention the lousy 10mpg I get around the city. New O2 sensor, CTS, IAT sensor and lord knows what else. IAC, timing and TPS are all set within acceptable parameters and gas mileage is still shot to hell, even with the terribly tall 2.73 rear end. What gives? Any ideas anyone? I would sure appreciate if u guys could throw some ideas at me . Thanks...
Old Sep 15, 2002 | 02:05 PM
MdFormula350's Avatar
i say you should get another chip, one meant for your car..
they must be different because the chips are made for what your car has..
see if you can get a custom burnt chip from some one on the boards.
Old Sep 15, 2002 | 03:08 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
any idea how much it typically costs to have a custom chip burned?
Old Sep 15, 2002 | 04:18 PM
86IROC-SS's Avatar
id expect your fuel curve to look like ***, i think the 5.0s had 18# injectors compared to the 5.7s 22# injectors. Im sure there are some other computer diffs. too. Most guys on this board will tell you to just buy stuff to burn your own chips, but i personally dont have much patience to do that. Read Traxions intro to Prom burning article. Ive read it half a dozen times, but im still not convinced to start burning my own chips.
Old Sep 16, 2002 | 12:46 AM
Tonyrodz's Avatar
Transmission: auto
I'll swap you! I have one from an 86 305 tpi auto-and I need one for my 89 350 tpi. E-mail me if you're interested.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
