wiring in a/f ratio guage...
Old Sep 22, 2001 | 01:16 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
has anyone wired in a a/f guage on a non computer car? the instructions says to connect one wire from the guage to the wire on the car that goes to the PCM. My car doesnt have a PCM. Will it work if I just directly connect this same wire to the 02 sensor?
Old Sep 23, 2001 | 11:46 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
If you have a O2 sensor all you have to do is connect the signal wire on the gauge to the wire on the 02 sensor.
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Headers, Rebuilt B&M 700R-4 tranny, Airfoil, K&N's
-- Blue LED backlight Dash
"Just some 17 Year old spending every dollar I make on my car."
Old Oct 2, 2001 | 02:46 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Do NOT splice the O2 sensor wire!!! It gives you a bad reading. If you splice into the wire on the ECU then you get a nice and clean signal. I think the wire you need is #13 (brown) on the second plug. Do a search on the exact wire.
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    !cat
    CAI W/ K&N
    15.559 @ 88 MPH
    (Not good enough)
Old Oct 7, 2001 | 10:06 PM
92fire-audio's Avatar
Really? That's great. I'm definatly getting one of those now, I didn't know you could keep all the wiring in the passenger area, now this is perfect. I don't ever like running wires from the engine through the firewall..
Thanks for letting us know you can use the wire off of the ECM..
Reddeath210
Oct 6, 2015 08:20 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Bryan F
Aug 27, 2015 07:28 AM
hectre13
Aug 26, 2015 08:17 AM
happyhapka
Aug 15, 2015 04:42 PM
