need help with Autometer monster tach
Old Oct 14, 2001 | 11:31 PM
GOLD85's Avatar
well i got a free monster tach from my budie of his race car.but 3 of the wires where riped out(vandals) anyway i need a schematic diagram of it, would your guys know where i can get one
when the green flag drops the bull$hit stops
pulled the 350 to make way for the 406 wich is in the machine shop. got a comp 282S bump stick with 1.6 rockers. looking at differnt heads right now.Perfomer RPM and holley 650 DP, headers and 3 inch exhust. 3000 stall converter and a built 700r4. shotin for mid 12s next summer
Old Oct 15, 2001 | 04:10 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
What are the colors of the wires coming out of the tach?
Here's what the following two colors generally signify:
Red: +12 volt ignition power
Black: ground
There should be two other wires coming out of the tach, as well; tach input, and dial light power.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Oct 15, 2001 | 05:16 PM
GOLD85's Avatar
i realize that, but the wires are riped clean from the circut bord
Old Oct 16, 2001 | 03:19 PM
If that's the case, then you should be able to easily identify the ground and light traces by ohming them out or following them to the back light. The ground will go to many other places on the PCB, while the light input will go only to the back light. That leaves the other two inputs - the power input will go to many places on the PCB, while the tach input will only go to a few locations. There will probably be a large polarized filter cap on the power input, as well, which should help affirm the wire ID procedure.
Tim
$750 L98
Feb 1, 2025 02:25 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Eric-86sc
Sep 28, 2015 11:37 AM
TrevinE
Sep 14, 2015 03:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
