Wire routing
Wire routing
How do you guys have the wires for any custom accessories or toggle switches routed. I am trying to wire in the secondary fan toggle switch. I am trying to get the wire to follow the main bundle through the passenger side fender. I have been unsuccessful so far. Any suggestions for getting it through? Any other places I can route the wire that are discreet and accessible?
Robert
1989 GTA TRANS AM
Was a TPI 305 & t-5 car.
Is now 383 stroker w/ the same T-5
World products Sportsman II heads(64cc fast burns). Lunati pistons@10.5:1 and 452/462/112* camshaft. Eagle crank and 6 inch rods. Ported/polished/port matched stock TPI intake. T-5 on a suicide mission.
Robert
1989 GTA TRANS AM
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you have cruise control,, there should be a grommet you can poke the wire thru just behind the lip of the carpet behind the brake pedal.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I drilled a small hole behide the passenger kickpanel and ran a wire though that.
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported Plenum
-- Blue LED Bakelite Dash & Climate Control
"Just some 17 Year old spending every dollar I make on my car."
Lightly Moded:
Glowsock
Jan 9, 2017 04:06 PM
