What's the switch I need to replace to make my brights work?
Old Oct 21, 2001 | 07:12 PM
crazeinc's Avatar
Hey guys. I've lost my Chiltons. My brights only work if I lift my steering wheel into the top position and try clicking them on about 10,000 times. I remember there's a switch you replace to fix this, but does anybody have the part number and idea of how much it costs?
Also, how do you replace it...I'm sure it's a bear since it's in the steering column.
'90 GTA...nitrous is your friend
Old Oct 21, 2001 | 07:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
About $10-15 from 'the zone'
It actually mounted on the column rather than in.
Easiest way (imo) is to remove the 4 nuts holding the column to the dash (easily seen w/the 'hush' panel off. Then the switch is accessable (upper left side of column down by the brake pedal). 2 hex screws, a plug, old switch off, new switch on, plug back in 2 hex screws, back in business.
Limited space (unless you're a smaller person), makes it a bit harder than stated above but, not too bad.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Oct 22, 2001 | 03:44 AM
crazeinc's Avatar
what's the actual name of the switch so they don't give me a blank look?
thanks for the help, that sounds very easy...I'll be sure to thank the bastard that told me it was hard and that's why I've been putting it off
[This message has been edited by crazeinc (edited October 22, 2001).]
Old Oct 22, 2001 | 04:54 AM
deadbird's Avatar
Engine: TPI 305/ v6
I just asked for the high beam switch when I got mine. Hard/difficulty is determined by how lazy one is (for most average repairs)...
[This message has been edited by deadbird (edited October 22, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
TheExaminer
Aug 26, 2015 04:59 PM
NBrehm
Aug 25, 2015 11:49 PM
Fronzizzle
Aug 9, 2015 01:15 PM
