hatch blows fuse
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
hatch blows fuse
i have an 83 bird and whenever i pop the hatch with the button, my 20amp(radio, hatch release, domelight) fuse pops. Anyone know why? Im thinking bad button because there are no cut wires
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you checked the wiring in the back, under the plastic, to make sure no wires are grounding out on the body ?
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
Engine: TPI 305/ v6
You might try unplugging the relay back there & then pressing the switch to see if the fuse still blows. If it does then the switch could very well be the culprit or there is a short in the power wire that runs to the back. If it doesn't it may be a problem with the relay or the solenoid might be on the verge of toasting. Other than that I can't think of anything else it would be since the problem is only intermittant w/the use of the button.
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
