digital dash to non-digital
Old Oct 24, 2001 | 10:39 PM
85berlinetta19's Avatar
is it possible to change a digital dash to a non-digital dash? I hate mine and would love to do a swap. Thanks in advance for the advice.
Old Oct 25, 2001 | 07:43 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
You hate your digital dash.. why? does it still work, because I actually want to switch from what you want to digital... and I wonder how hard that would be....
Okanagan Thirdgen Association
_ _____________________ _
89 RS Camaro, LO3 305 TBI
Autometer Air/Fuel Ratio Guage
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
Old Oct 25, 2001 | 09:47 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Yes you can change the gauge cluster out.The only things you have to do is replace your temp and oil pressure senors from switches to sending units.I would keep your analog gauges FastElectrics. First and the most important to me is the tempature gauge that only comes on when the motor has died.It happened to me
on my way home from work,my lower radiator hose came off and my car overheated and died and blew both head gaskets and cracked both heads.The bad thing about it was the d@mn gauge light never came on to warn me :angry:
But its your car and you can do whatever you feel nesscary to it.
[This message has been edited by 85SportCoupeto89RS (edited October 25, 2001).]
Old Oct 26, 2001 | 07:44 AM
Car: 89 Camaro RS
Engine: 305 TBI
In my car I don't have "switches" I have "sending units", no lights inplace of guages.. are you saying the digital dash in the earlier camaros didn't actually show a "temperature" or "pressure"??
Old Oct 26, 2001 | 06:18 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The digital clusters in the Berlinettas do show oil pressure & water temperature, as well as voltage via analog gauges. If you want to swap in an analog cluster into a Berlinetta, you would most likely have to change the dash out, as well, since I believe that the Berlinetta digital clusters fit in a different form factor than the analog clusters. Also, unless the analog cluster was setup for an electric speedo ('90 - 92), you would have to rewire the cluster to bring in the VSS signal, since the VSS buffer is located on the rear of cable driven analog clusters. Also, the cluster plugs are different between analog (dual plug pcb mount) & digital (single high density pin type) clusters.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Oct 26, 2001 | 09:16 PM
thanks for all the help guys.
Old Oct 26, 2001 | 09:49 PM
Car: 85 Camaro SC
Engine: V6
Thats odd my digital cluster never showed anything.When I turned the car on the gauges would light up and then shut off.They wouldnt come on while i was driving.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
