Fuel Pump Prime Wire
Old Oct 28, 2001 | 05:45 PM
Tad's Avatar
Tad
I have 87 camaro LG4 that I'm converting to TPI. I'm using a speed denisty harnes and I'm trying to figure out where this wire goes. I know it comes of the fuel pump relay but can't seem to find out what it pulgs into. Also where is the A/C pressure switch located at is it the one on the acumlator or on the back of the compresor?
Tad
Old Oct 29, 2001 | 01:56 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The fuel pump prime wire is meant to hang loose in the engine compartment - it may be powered directly from the battery to run the fuel pump while the engine is not running.
There are two high pressure switches in the A/C system. The switch at the compressor opens the A/C clutch circuit if the head pressure exceeds the set point (around 325 psig, if I remember correctly) of the switch. The switch located on the liquid line (the pipe between the evaporator coil and the condenser coil) closes the secondary fan relay coil circuit above its set point (232 psig).
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Oct 29, 2001 | 07:12 PM
Tad's Avatar
Tad
Thanks Tim
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
